2004 Kia Rio Cinco Rear Wheel Bearing Nut Torque
Old 08-08-2010, 01:44 PM
Slow as Shit
Woodrow's Avatar
Default Re: 2004 Kia Rio Cinco Rear Wheel Bearing Nut Torque
Originally Posted by Fabrik8
1994 Kia Rio + 16 model years since then = Probably
By the way, you can probably visit a dealer service department and they'd tell you if you asked nicely.
Slim chance, but maybe. Sometimes, we can't stand being bothered by people who just want "free advice", especially when we are busy. If a person doesn't know the info or can't find it, they shouldn't be touching it.
Woodrow is offline
Old 08-08-2010, 01:55 PM
management
boredom's Avatar
boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom
anytime ive gone and asked for specific info for my mom's car (lincoln) ive either: a) not been told or b) been told they dont know, but can do the work for me
google told me 190 ft-lbs tq tho OP
boredom is offline
Old 08-13-2010, 12:45 PM
The Pro to call.
HatefulMechanic's Avatar
You searched incorrectly. Front wheel bearing torque is that, but the rear is a standard double taper roller bearing.
Torque them to 190 ftlbs and see what happens.
HatefulMechanic is offline
Old 08-13-2010, 05:24 PM
management
boredom's Avatar
my bad.
i almost thought your reply was serious until i realized i had never heard of a double taper roller bearing...almost googled it too
boredom is offline
Old 08-13-2010, 06:16 PM
my bad.
Seriously? Many non-driven rear bearings are tapered rollers and need to have a proper preload adjustment. A lot of cars have a cartridge unit (like Civics) and are pretty much the same as most front bearings in FWD cars where you just torque to a certain spec. The difference is that the double taper bearings are two separate bearings so you're actually setting load of the two bearings in relation to each other. The cartridge bearings are just a single bearing unit and you're just torquing against the single solid center sleeve of the bearing.
What I want to know is why the hell Kia uses double taper rollers? They must be cheaper, because there isn't really any other reason to use them nowadays on the rear of a FWD car. Actually, if they're a torsion beam rear, that would probably explain it. But it's still most likely because the bearings are cheaper.
Old 08-14-2010, 04:25 AM
The Pro to call.
Thanks for quoting before dipshit could edit. I was enjoying "The Expendables" and didnt feel like dealing with this thread.
First damn result in google
They use a solid beam axle, which is cheap to make, even cheaper to use two taper roller bearings.
oneCAMonly
07-06-2010 09:22 AM
Venom98Hatch
11-09-2009 09:37 AM
FlipLegend
01-03-2005 05:48 AM
Quick Reply: 2004 Kia Rio Cinco Rear Wheel Bearing Nut Torque
